For those of you that are processing lorry loads of soft or hardwood.
1, At what price per m3, tonne or lorry load would you stop processing your self & use a contractor to process for you?
Assume that you still need to help to remove the split logs & poss move logs to the contractors machine.
2, Would the price differ if the contractor could do larger diameter logs than the sub 35cm / 14" typical processor feed stock?
a, up to 50cm
b, up to 80cm
3, What length do you typically cut the logs too?
a, 8"
b, 10"
c, 12"
d, 14-18"
e, up to 1m billets
4, How much production can your handling side cope with per day?
a, 1/2 lorry
b, 1 lorry
c, 2 lorries
d, other
5, What else would encorage you to change over to using a contractor?
a, log cleaner
b, log pallet bundler / wrapper
c, self loading so you dont need to load the log deck
d, site left clean
e, contractor bringing a loader/skidsteer / tractor etc
f, other
Unless the contractor can do every part of the job for £10per m3 I'd rather do it myself.
And I wouldn't go out for that as processor and man unless it was guaranteed 10-16" timber.
Inc taking logs away to be stacked, or piled?
Or would it be your responsibility once its off the conveyor?
No, not including that.
I'd definitely consider contractors if I couldn't keep up with output ourselves or wanted to do double the amount earlier in the summer perhaps.
We used contractors till it got the point we were selling over 100t a year.
I already do £10 per m3 for vetted clients that dont slow me down by bad site, wood or helpers.
They are expected to clear all cut logs & keep the wood pile right up to the processor so I only have to roll onto the lifter.
Currently do about 1/2 lorry per day but thinking of changing processor to up that to 1 or more.
Due to investment & larger running costs not sure if that could also bring down the per m3 price or not.
  • 1 month later...
This is somthing I’ve been thinking about doing for a couple of years now,can’t seem to find anyone close to me though gl6 glos prob got 50/75 ton in the yard no ready for processing,wouldbuy it in ready processed at the right price .anyone on here want some subcontract splitting pm me I have telehandler on site and bins for storage.
