So a tryes to replace my bosses throttle cabel as its stretched on the hrd 536 with a genuine cable so i fitted it but i can get it adjusted properly each end and so when i pull doen on the control lever it shuts off which o cant get it to do the wire jusy bends up on the engine as if its to week to put the mechanism back tried everything
Thanks mate but no a nees to know how to  set up the adjusters at the throttle levet end the nuts and then the screw clamp position om the engine bare in mond this new cable has a spring also on the engine end instead of just a solid outer cable casing like the one i took off
