Didn’t know they did one but I’m sure a Chinese stump grinder would be less than just the attachment and work as well if not better.
everything bcs is wildly overpriced and suffers design compromises to make it modular. You could accept that if there was a saving over buying a whole different machine but usually there isn’t!
Those chinese ones are not self propellered and won't help you on inclines or ramps. With the bcs you could use the steering brakes left or right to block a wheel and use the self drive for climbing yout own grindings in front of the wheels even if it means to fight the levers and shift like a man.
The AV on the handle could be problematic on the long run maybe.
Never used one but am tempted as well in order to get rid of my non propellered walk behind. From my experience the upgrade to Multi tip will be necessary to get rid of the drag in the grindings.
Just my thoughts, never used one.
