I have a bent 'Drive Belt Tension Adjuster Bolt' on my Greenmech CS100 18hp .... Does anyone know how you can get the Drive Belt Tension Adjuster Bolt & Pulley Spindle Bolt (Link through each other) out of the enclosed frame work so that I can replace them both? Because it looks bolts are sealed within the frame work of the chipper body.
The  Adjuster Bolt is a M10 x 100 Eye Bolt (Part Number: 910100EB)
The Pulley Spindle Bolt is a M10 x 80mm (Part Number: 91080) that feeds through the Adjuster Bolt..
Hi Jamie,
If you remove the cassette assembly you should see the hole for the spindle bolt to push through which will then allow you to remove the 12mm eye bolt.
Just make a note of where the washers are fitted..
Jase.
