BS4043 clearly states: The diameter of the prepared root ball should be at least 10 times the diameter of the stem measured 1 m above the ground.
its best to check that the supplier has adheered to this for the best chance of survival, however when i have transplanted some extra, extra heavy stadards (12m+ & 60cmg+) i have found some root balls to be lacking and found out that this is due to the tree spades being too small. I often wondered if any1 in the states has/ makes an extra big one?
so best thing to do is probably measure the root ball as aposed to the dbh & work off a density of 1metric tonne/ m3
  David Riding said:
Is the a general formula for estimating the weight of a root ball going of say dbh, I realise this will fluctuate from tree to tree & change depending on ground conditions.
a big set of scales:001_smile:
Read more
