Has anyone seen any issues arising from too much oil in the engine, I’ve drained some off but could this have caused any issues associated with injectors, vicoscity of oil looks ok don’t think diesel leaking into it.
  • 4 years later...
10 hours ago, Scott treadway said:
Having same issue of not starting with shut off solenoid removed the rack is fully to the right. I’ve figured the rack is stuck in the shut off position. Just run it two days prior.  Any help would be appreciated.
Can you get hold of the rack with needle nosed pliers and pull it gently?
  • 2 months later...
Has anyone on here had any luck finding the source of their problems? I have a Greenmech Eco Arborist 150 with the same engine. I was using it on a job, shut it off and it won't restart. I think the little 12v fuel pump sounds a bit loud now, but I took the line off the 'out' side and it was pumping fuel. I'm not much of a mechanic, but with it being an old machine and me being stubborn, I'd like to fix it myself.
Any help is much appreciated!
