My petrol strimers stopped working, I get the engine running but it’s not spinning enough to cut the grass. When it comes into contact with the ground it just stops spinning, any help would be appreciated
thanks
1 hour ago, Ewan1738 said:
? it’s 7 days out of its warranty
Is it a " bent shaft " type with a flexi drive inside . If so it may have worn out the square that the flexi fits into . If its a strait shaft with a gear box on the end then thats more expensive .
