Hi All,
 My parts list is for a regular carb machine and doesn't have any part numbers for the fuel solenoid.
I don't seem to be able to find the part number anywhere.
Can anyone help with an M-Tronic parts list or the part number I'm looking for please.
Thanks
Bob
attached is the older parts list I have
MS261_parts.pdf
1140 007 1802 is the “upgrade” kit. Comes with white solenoid and up rated fuel filter, £17.73 +VAT. Hope that helps. If yours is fitted with a black solenoid, up rate it, if it’s fitted already with a white one, that’s the part you’ll need.
It’s compatible with all control units, I think I have a gen 1, and the white solenoid works fine.
Hope that helps.
On 27/04/2020 at 10:49, Stihl123 said:
Sorry for the delay. I've used this site and I've never seen those diagrams before. Cheers.
Hope that helps.
I've seen this part number quoted before but can't get any results on any of the parts sites I use. Thanks for the effort though.
Cheers Bob
Cheers Bob
It isn’t on the parts lists I could find, but I ordered that exact kit from L&S, received it and fitted it, and works a charm. Conversation below I had with L&S about the solenoid kit, no parts list on their site, but miraculously sent me a screen shot of the upgrade kit, which looks suspiciously like a Stihl exploded diagram, weird.
  • 1 month later...
5 minutes ago, Heavy Oil Saw said:
[mention]Bob_z_l [/mention] I was wondering if you got a solenoid sorted in the end?
I did get the same answer from LS as you. I just haven't chased it.
As usual...when I started to try and fix it the saw has been running like a swiss watch... Dag-nabbitt.
I'll order the parts and have them in the "bin" when I need them.
Thanks
Bob
Always the way with stuff, leave it and it packs up, try and look at it/repair it and runs the best it ever did, makes you wonder if there ever was a problem. Glad your up and running, always best to keep a spare on hand, the old one will go at the most crucial time, Sod’s law.
