2 hours ago, Silverhooker said:
I agree 1/64th here or there won’t make a discernible difference in the real world. More important to get angles correct, correct height and shaped rakers. As “Bucking Billy-Ray” would say “gotta clean out the gullet”.
Because everything to do with the cutter is tapered ( from the cutting face back ) to give clearance . When you have sharpened a cutter back a long way the lower part of the gullet can end up as wide as the top plate or a bit wider and this will cause it to rub in kirf . So yea . Clean out the gullets from time to time .
Edited by Stubby
