Hi all
The guys were using this the other day , had it out the maximum length and now it wont go back in. Its rock solid! cant turn it or go in or out.
i loosened the bolts that are by the orange release lever that is used normally to move it in or out but nothing.
I am afraid to do anything to brutal as its all soft aluminium and plastic.
Has anyone experienced this and has a solution?
Sprayed lube in it but not made a tiny bit of difference.
Many thanks
No joy. I tied it all but to no joy. I think what happened was the plastic sleeve had broken off from the 2 indent holes that hold it in place and had gone down and wedged in , jamming it solid.
solution?
hacksaw!
it was coming out one way or another. It’s now about 60 mm shorter but at least I can extend or shorten.
cheers
