its pretty cool, but i think you would be better with sticking a cylage grab on a linkage
I am not familiar with silage grabs. Can a silage grab drop a load of limbs or logs? It is important to make a loose pile with all ends in the same direction so individual limbs can be pulled out by hand days or weeks later. The chipping is usually done by others.
Thanks
They were mostly made by Werner (Werner Forst und Industrietechnik) who have had a long tie-up with Merc.
Werner makes most of the winches you see on mogs (the big red PTO front, rear & mid-mount forestry single and double drum) they also made the skidding plates (belly plates etc to protect from branches etc) and the butt-plates/sprags
They also own the rights to the MB-Trac and made it for a wile before renaming it to WF-Trac which is still made now.
To get one to the USA speak to Scott at EI as he ships containers to the USA and I think has someone in Belgium/Germany who deals with it this side of the pond so you may only have to get it moved to there then pay a shipping fee to Scott
Edited by b101uk
