10 hours ago, daltontrees said:
There's a  country park near me that is quite boggy in places, and in the middle there are loads of willows that defy identification. At one end the'yre definitely caprea, and the other end I'd be comfortable confirming cinerea. But in the middle there's all sorts of mad combos and at least one other species in the mix, aurita I think.
I found this explanation today about Grey Willow, which I thought was helpful.
Grey Willow and Goat Willow collectively are known as 'Pussy Willow' because of their silky hairy buds in early spring.
Easily mistaken for Goat Willow (Salix caprea) (which also has 2 sub-species as does Grey Willow), the differences being:
  • If the bark is peeled off 2-year-old twigs, then the exposed surface is ridged on Grey Willow (but smooth on Goat Willow)
  • The bark of Grey Willow grows darker and has shallower ridges than that of Goat Willow
  • The leaves of Grey Willow are usually much smaller and between 2 to 3 times as long as broad and broadest beyond halfway to the tip
  • Grey Willow (the much more common ssp. oliifolia sub-species - which is sometimes known as Rusty Willow) has fine felty hairs on the underside of the leaves and rusty-looking hairs along the veins on the underside of the leaf (whereas Goat Willow does not)
  • The flowers on Grey Willow also start later than those of Goat Willow
  • The softly-furry 'pussies' are slightly larger on Goat Willow
  • Grey Willow is much less often found away from damp areas than is Goat Willow
But, the hybrid of Grey Willow with Goat Willow is common.
It is native and a shrub or small tree growing to 6m high (15m max), thus usually smaller than the similar Goat Willow which is 10m high, 19m maximum.
Grey Willow exists as two sub-species:
  • Salix cinerea ssp. cinerea (which is much less abundant and mainly occupies fens in a triangle between Burton on Trent at the centre, with Hull at the northern limit and Gravesend at the southern limit. Although in the last 10-15 years it seems to have departed from most of Norfolk and since the turn of the Century from most of Northern Ireland, it has however been spreading very slowly in apparently random isolated spots randomly throughout the UK since 2010). This species is usually persistently hairy. The leaves are dull and hairy (or not) on the upper surface and densely hairy on the underside. Leaf shape is mostly oblong or obovate. At low altitudes this species is found on marshes and fens.
  • Salix cinerea ssp. oleifolia which is much the most widespread throughout the UK. The twigs become glabrous (hairless) as they grow. The leaves are mostly narrow-obovate or oblong and less glossy than those of ssp. cinerea and nearly glabrous on the upper surface. On the underside the leaves have grey hairs and some stiffer rust-coloured hairs along the veins. This sub-species is sometimes known as Rusty Willow for that reason. It is found in wet places, woods, both lowlands and uplands. It is the commonest species of Willow in the lowlands.
Hybridizes with :
  • Goat Willow (Salix caprea) to produce Salix × reichardtii
  • Goat Willow (Salix caprea) + Creeping Willow (Salix repens) to produce Salix × permixta
  • Eared Willow (Salix aurita) to produce Salix × multinervis
  • Eared Willow (Salix aurita) + Dock-leaved Willow (Salix myrsinifolia) to produce Salix × forbesiana
  • Dock-leaved Willow (Salix myrsinifolia) to produce Salix × strepida
  • Dock-leaved Willow (Salix myrsinifolia) + Dock-leaved Willow (Salix myrsinifolia) to produce Salix × phylicifolia
  • Creeping Willow (Salix repens) to produce Salix × subsericea
There are also 13 triple hybrids, namely:
Salix aurita × cinerea × phylicifolia
Salix caprea × myrsinifolia × phylicifolia (Salix × phylicioides nom. nud.)
Salix cinerea × myrsinifolia × phylicifolia
Salix herbacea × myrsinifolia × phylicifolia
Salix myrsinifolia × phylicifolia × repens
Salix viminalis × cinerea × repens (Salix × angusensis)
Salix myrsinifolia × phylicifolia × myrsinites (Salix × blyttiana)
Salix caprea × cinerea × viminalis (Salix × calodendron)
Salix cinerea × aurita × myrsinifolia (Salix × forbesiana)
Salix cinerea × purpurea × viminalis
Salix aurita × myrsinifolia × phylicifolia (Salix × saxetana)
Salix purpurea × aurita × phylicifolia (Salix × sesquitertia)
Salix aurita × caprea × viminalis
with four of them being hybrids of Dark-leaved Willow (Salix myrsinifolia) and Tea-leaved Willow (Salix phylicifolia) with another Willow. These hybrids are not shown properly on the hybrid chart above, being partially over-lapped by normal hybrids with just two parents.
There is also a one quadruple hybrid:
Salix × taylorii (Salix purpurea × viminalis × caprea × cinerea)
There are also five triple hybrids, namely:
Salix repens × myrsinifolia × phylicifolia
with four of them being hybrids of Dark-leaved Willow (S. myrsinifolia) and Tea-leaved Willow (S. phylicifolia) with another Willow.
Good research there.  That's why it could be S.caprea, or a hybrid of. Even if it looks most like S.caprea, it may not be 100%. If you grow willow seeds that are in a mixed species area; see what grows from a batch off one tree. That will give insight into how complex i.d is, and how it can be guesswork. I used to collect willows..BSBI handbook of willows and poplars by Meikle prob best guide if need i.d.
Hybridizes with :
Wow - Its a pimped up version of  White Pops and Aspen and their varieties of mixed hybrids
