I'm looking for the apical meristems of palms for a tree anatomy workshop at the beginning of August. I you are planning to cut palms (preferably 100-150mm dia.) around the end of July, I would be grateful hearing from you. It's in a good cause. All proceeds will be going to research at Cardiff University into decay in standing trees.
Mike Ellison
Edited by MikeEllison
typo
Not like you to not take stock of an OP’s request/question and try to swing things your way.
Sure he said 100mm - 150mm preferably [emoji848][emoji849]
On 30/06/2019 at 22:55, scotspine1 said:
Felled a 200mm last week. Any use? Need to be fresh cut?
Thanks, 200 would be at the limit of what we could use but it would need to be fresher than that. The workshop's on 3-5 August. I'm no expert on palms but the can be kept for a while if they're stood in water.
