Hello,
Its been a while since I was here.
I had the pleasure recently of my first stump grinding job which I really enjoyed actually! Did 22 conifer stumps which were a breeze. Then onto the next site. No idea what these stumps used to be. One was solid as a rock. Eucalyptus maybe? Anyway one of the other ones was quite fibrous and started to smoke! Enough to cause concern because it was blowing onto a busy road. Has anyone else had this happen? Is it normal?
Chris
If it was yellow in colour it's probably false acacia,  it's horrible if it's not fresh cut. I've had it smoking when the grinder teeth loose their edge. It blunts teeth quickly. Smells a bit of something dead.
I did a type of poplar which unlike regular ones had a heart that wouldn't chip but transformed into long fibres, heat and smoke.
Same with older picea, abies and pinus. The very centre is tough and fibrous making going tough.
 Stuart
