Vermeer Grinder teeth
CanopyKing
They are Vermeer 'Yellow Jacket' teeth mate which you will need to get direct from Vermeer UK.
http://vermeer-uk.co.uk/product/shop/
They cost £7.21 each but they are double sided and seem to last for ages anyway. You can also sharpen them a couple of times so pretty good value for money really.
They come in a plastic bucket which contained enough for two sets on my machine so that must be 60 teeth. That should be enough for 3 sets on your SC40 machine. However, you will only really need to change the outer ones (x4) often as the inner ones don't seem to wear much at all.
They cut brilliantly too!
SG
Edited by Stumpy Grinder
SG
Glad youve just put that up..... 7.21 online and im sure they just charged me 7.75 each over the phone.
Howiya lads cheers for the replies. We just bought a bucket from vermeer in sweden here 100krone a tooth.
You mentioned sharpening how you doing that? I get distracted by ads when i search things online so probably quicker to ask someone [emoji28][emoji111]
You mentioned sharpening how you doing that? I get distracted by ads when i search things online so probably quicker to ask someone emoji28.pngemoji111.png
Use a bench grinder with a 150mm diamond wheel. You can do the face as well as the edges as the sides are slightly angled.
