hi recently while using the  mower drive became so weak i decided to change belts on site but was not sure what needed to be removed to change the variator to gearbox belt so i just changed the crankshaft  to variator belt which improved the drive but it should be stronger . can anyone help how to change  the other belt regards peter
Obviously you'll need to remove the engine to variator belt again.  Then,  make sure the control is set to fast, then roll the belt off the variator as you turn it by hand.  Then slip it off the gearbox pulley, You might have to twist the belt sideways to allow the belt to slip past the spring anchor.   Belt is thinner inner to outer than it is wide, hence the twist to get it through the gap.
Spring anchor = A bent piece of metal just above the gearbox pulley, to which the other end or the variator arm spring is attached.
Hope this helps.
Just thought after I posted, you have removed the five screws and removed the cover part of the underdeck haven't you?  Left hand side as you stand behind the machine. (Obviously underneath).  ;)
Hope this helps.
hi my fingers just not strong enough   with the new belts being  a little thicker and stiffer .I will try removing the variator an remove the bolt securing gearbox that lets it swivel thus making a little more room .thanks will let you know how it goes ,peter
On ‎17‎/‎04‎/‎2019 at 22:28, IVECOKID said:
The Hayter vari drive is poor, i bought the conversion kit to make it single speed and drive problems solved for good .
The cost of the belts is ridiculous.
Ste
hi does the single speed conversion kit give a stronger drive .I under stand the speed is reduced but I doubt if mine is going very fast with the worn belts thanks peter
The  Hayter drive was never a strong  drive compared to the older PTO models , yes its slightly slower and  a bit more positive than the Vari drive.
Getting the old pulley off the crank was a pig , take into account how old your machine is and is it worth the money to change .
Ste
It basically gives the same drive system as the "Pro" version.  Give you a fixed double pulley instead of a variator, and that goes on to a new two piece arm and a spring which swings the double pully out to keep both belts tensioned.
Regarding the fitting of the belts, seriously it's not that bad, I do hundreds of them, and the 56 is the easiest of them all.  Usually takes about ten minutes on a bad day.  Remove the air filter, and tip machine on its right hand side (standing behind it), and you should be able to get to it ok.
Anyway, hope you manage to sort it.
