I had a trail camera in a tree. When it’s slightly breezy it goes off every couple minutes!
Sounds like a cellular one won’t be that good then as it might cost me a fortune keeping the sim payments up.
Hi Tony,
Same as you I needed some security where there's no power supply. If you find a good one that goes straight to the phone it'd be good to know.
I had a good look around and went with these a year or so ago as they have no lights to give them away...
https://www.amazon.co.uk/gp/product/B078S3QTDK/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 on the budget front and am very happy with it.
plus https://www.amazon.co.uk/Stealth-Cam-No-Glo-Camera-STC-G42NG/dp/B01N1A2NN7 as it is meant to be a good quality one though have just noted the poor amazon reviews.
If buying again, at the money, I would prefer to buy a couple of the cheaper ones than one more expensive one. I've got a little experience with these, also my father uses them on the trail to record animals and the trigger times can mean you miss what you needed to catch. A couple of cameras with different angles gives a better chance of catching what you want. Especially if on photo setting. I find 20 second video setting gives enough time for whatever has triggered the camera to appear on the shot. It might be triggered by noise or an animal just on the edge of the sensor so with pictures and the 'reset' time I find video best. You really have to keep on top of making sure you have enough memory space and battery power though. I'd also recommend 2 memory cards for each camera - when one is full, you can take it out, put the replacement in and then you've got time to view the footage with the camera still working. I was using mine to catch scum and it's pretty gutting to miss something because the memory card was on the kitchen table waiting to be checked from the last instance!
The Gosira is sensitive enough to pick up a fly at night on some clips. I guess location is important with trees and grass setting it off, though it's only in really bad weather that I find it's been triggered like this.
With some makes - like the stealth above you need to have certain memory cards - they only work with high end sandisk for some reason, best to check forums / reviews before ordering everything. The Gosira above seems to work with anything.
Good luck!
