Stihl 026 won't start
Dazonit
Well carb kit came today striped carb blew it through with the air line fitted card kit and it firerd up after 5 pulls cut a few logs it run sound and fired on first pull when turned off so seems to have done the trick . Thanks all for the advice all much appreciated
Drain the fuel by emptying the tank and running the saw till it stops if you are leaving it for any length of time and you will not have to do it again hopefully.
