This stack is about 4' high and the logs are about 4' long.
Look at the gaps.
If you had big straight logs you'd get a better return.
But you will always have air with cordwood as its rarely straight.
The traditional Breton way is to have a 3m3 cord of 1m logs stacked.
Walk along the top with a big saw 3' bar down the middle.(not recommended)
Use a plank to make life easier.
As you cut, the stack drops considerably.
Have to top it up to make 3m3.
[emoji106]
