Acidity of the oceans
treemeup
I've just been reading about this and it sounds quite worrying and cant be disproved by whoever as it is basic :confused1: chemistry, this got me worrying what will happen to these levels if the siberian permafrost melts and how the release of co2 could be best combatted.
I remembered a post a while back about mycelium and its ability to use carbon in its growth processes(it was a utube lecture vid) and was wondering if any of you clever fellows out there might know if planting the stuff around the permafrost it might use the carbon as it becomes available from the freeze?
I appluad your enthusuiasm. The carbon emmitted from ice is a natural occurance, its just that we are accelerating the temperature increase.
In nature the worlds climate completely changes every 28'000 years. I.e. we would have an Austrailian climate by that time. The it slowly changes back over another 28'000 years. Human effects on climate change is creating an added temperature increase on top of the natural one.
Without human interference, the carbon emmitted from warming permafrost would be absorbed by another carbon sink elsewhere. Ocean/rainforest/soil etc. It doesnt have to be on the edge of your permafrost.
Therefore, we can do our bit to
a) reduce our carbon/methane/nitrous oxide/sulphur emissions
b) increasing carbon sinks
Ice is also a mirror which reflects high energy shortwave UV from the sun. The less we have, the more the land heats up, the more the ice melts.
Oceans are heating,
not the atmosphere
Global Warming Not Caused By CO2
Background Science Explained Here
Gary Novak
Independent Scientist
Science Home
Global Warming:
Global Warming Main Page
Crunching the Numbers
Absorption Spectra
Explanations
Oceans not Rising
Future Ice Age
Acid in the Oceans
Context
The Cause of Ice Ages and Present Climate
Summary In Simple Words
CO2 Charlatanism
IPCC Propaganda
The Water Vapor Fraud
The 41% Fraud
The 30% Fraud
Stephan-Boltzmann Constant
The Disputed Area
A Fake Mechanism
Global Dynamic
"Delicate Balance" Fraud
Thermometer Manipulations
Heinz Hug Measurement
Fake Data—The Hockey Stick Graph
Global Dynamic of Carbon Dioxide Production
Because oceans are alkaline (pH 8.1), they absorb all carbon dioxide from the air, but salt drives out one third the amount of CO2 plants need to grow on. Without salt in the oceans there would not be enough CO2 in the air for plants to grow on.
1. The standard method of studying CO2 in a laboratory is to absorb it into an alkaline solution. The oceans are alkaline.
2. If oceans weren't regulating the amount of CO2 in the air, the graph would be all over the place. Some years would show two or three times as much as other years. Instead, every year is identical with only a few parts per thousand change per year.
3. Oceans exchange CO2 with the atmosphere at 19 times the rate humans produce it. see numbers
4. Carbon dioxide is not a pollutant. Biology depends upon it, and there is a shortage. Corals remove carbon dioxide from the environment by creating calcium carbonate reefs from their shells.
5. Carbon dioxide in the oceans is improving coral reef production, contrary to the acid-in-the-ocean fraud.
A turning point for some scientists occurred decades ago when some jackass said the oceans are in layers, and the surface layer is too thin to absorb much carbon dioxide. The claim is absurd, because the ocean surface is alkaline with no detectable increase in acidity, which means it is going to absorb carbon dioxide regardless of how thick the surface layer is said to be.
Propagandists are claiming that 33-50% of the CO2 which humans put into the air is absorbed by the oceans. There is no method of measuring the amount. Since the amount is contrived, it changes with convenience.
It is unscientific to split the CO2 into two quantities—the amount absorbed by the oceans and the amount left in the air. There is no force in nature to split the quantities.
The real force of nature is equilibrium. This means CO2 moves into and out of the oceans at a controlled rate determined by salt content, pH and temperature.
Since the surface of the oceans is alkaline (pH 8.1), CO2 is absorbed with great vigor, and only high salt content allows a small amount to be expelled. Increased temperature allows an increased amount of CO2 to be expelled. Since the oceans were much warmer during the dinosaur years, there was five times as much CO2 in the atmosphere.
On this basis, oceans are allowing 385 ppm CO2 in the air regardless of the amount humans produce. The oceans are taking out all of the CO2 that humans produce but releasing increased amounts due to increased ocean temperatures.
The effect of temperature is demonstrated when an El Nino heats the Pacific Ocean. CO2 measurements in the air show an increase; and when the El Nino subsides, the amount of CO2 in the air returns to normal.
Real science shows that CO2 doesn't hang in the air for centuries as propagandists claim. The oceans exchange CO2 with the atmosphere at 19 times the rate humans produce it. So the human effect disappears in the forces of nature, and the global warming scam disappears with it.
On a long term basis, CO2 is tied up in the oceans as calcium carbonate in coral reefs. Propagandists claim that increased carbon dioxide is destroying coral reefs by causing the oceans to become more acidic. There has been no measurable increase in acidity of the oceans, because the amount humans produce is miniscule compared to the ocean's capacity. The surface oceans contain 1,000 GTC, and it does not stay there. It circulates into the deep oceans, and it gets used in producing coral reefs. The intermediate and deep oceans contain 38,000 GTC. Humans add 8.5 GTC to the air per year.
The implication of corals being damaged is a fraud. No measurement has ever shown coral damage due to carbon dioxide or acidity. All coral damage is caused by other factors, such as temperature increase, while humans cannot cause ocean temperatures to increase. The oceans have a thousand times as much heat capacity as the atmosphere, which means the miniscule and contrived temperature increase of the atmosphere is not the cause of oceans heating.
Acidity caused by carbon dioxide cannot harm corals, contrary to fraudulent claims from recent science. Both the theory and fake studies are a fraud in claiming acidity destroys the ability of corals to make shells from calcium carbonate. No direct measurement has shown damage to corals from carbon dioxide entering the oceans.
The theory is a fraud, because it refers to “acidity” rather than carbonation. Dumping acid into an aquarium in a laboratory is nothing resembling carbon dioxide entering the oceans. The theory says that acid reduces carbonate, which it does. But carbon dioxide isn’t just acid; it is in equilibrium with carbonate. Equilibrium means the more CO2 that is added, the more carbonate there is. Honest scientists know this and have explained it to no avail.
This means corals grow better as carbon dioxide enters the oceans, particularly since the oceans have such huge buffering capacity that no detectable acidity has occurred as a result of CO2 entering the oceans.
Corals have been removing carbon dioxide from the environment for tens of millions of years. The small amount that humans add is a slight correction for the benefit of corals, not a harmful effect on the environment.
The most significant fact of this whole subject of carbon dioxide and global warming is that increases caused by humans are so miniscule compared to natural variations that any harmful effects would have occurred naturally many times over. Yet nature survives ice ages every 100,000 years and similar effects which totally swamp anything humans do.
A new study and web site explains the oceanography of carbon dioxide and shows the errors of the propagandists who claim that increased CO2 in the oceans will make the oceans more acidic and destroy coral reefs. Near the surface of the oceans, increased photosynthesis creates alkalinity rather than acidity. There is in fact a shortage of acid near the surface for the promotion of photosynthesis. The decay which creates acidity occurs 1-2 kilometers down, which is way below the level of coral reefs.
This subject is explained by Dr. J. Floor Anthoni here:
New Oceanograhy Study
CO2 is good, not bad — Roy Spencer
Is this a cut and paste document?
Basically on the principle that Carbon is a necessary part of our planets ecosystem, which of course it is.
Unfortunately you are not taking into account the other harmful emmissions. The word Carbon is commonly used to describe the six most harmful emmissions. Carbon Dioxide being the least harmful but the most prominent.
Methane for example is 23 times more harmful to the environment than Carbon Dioxide.
Nitrous Oxide is 296 times more harmful than Carbon Dioxide
Perflourocarbons are 5000 to 12000 times more harmful than Carbon Dioxide.
There are many scientists on both sides of the arguement which give valid arguements. So it comes down to the question, does our ever increasing population's reliance on fossil fuels, producing these emmisions have NO effect at all? Highly unlikely, as we are seeing evidence of the climate changing in a pattern and rate which currently should not be seen.
As far as the oceans are concerned. We have destroyed so much coral reef through intensive fishing practices that we have had to protect what is remaining by international law. Therefore this tiny amount cannot be expected to convert the same amount as it was before intensive fishing became the norm.
Also, the oceans react incredibly slowly. Therefore what we and the planet produce in emmissions today, will not show an effect in the oceans perhaps for over 100 years.
been away, sorry. This has turned in to a bit of a global warming thing, which seems to happen between politicians and scientists in their debates (not solutions but is it really happening and why), the way i see that is if i put a large paddling pool in my garage, with some coral and fish, a couple of small trees and a few blocks of ice then started my saw, i'd probably last about 10 minutes but then have to get out of there, i figure the world is like this but on a bit of a larger scale (I like to simplify things quite a lot)
I guess it may be a bit cold in siberia for mushrooms, but i figured if the permafrost is melting then the temperatures in that area are above freezing and so long as they don't die then they wont release the carbon they're fixing.
So how about in Indo? its a bit of a problem there too, would the mycelium fix enough carbon to be worth planting the stuff?
Doug I appreciate its a natural process but i think we humans have accelerated things so much that every possible way of reducing methane, co2 etc release should be being done, and as we are obviously not going to reduce the burning of fossil fuels anytime soon then we need to combat the natural processes.
I couldnt agree more.
Your idea isnt actually as far fetched as some other adaptation ideas. For example, a huge mirror in space! And sprinkling reflective sulphur particles in the upper atmosphere.
Believe me these are options which have been seriously discussed by the powers that be...
If Mycelium is an effective carbon sink, it should be encouraged where practicable. Basically, a higher value needs to be placed on these sinkks (including the ocean/corals) in order to become economically protected from exploitation.
Raising awareness on this wide ranging issue is the first step, which you have taken by entering into public discussion on the subject.
Practical forestry and effective, sustainable arboriculture can help mitigate/adapt to climate change. Maybe in a small way, but every little helps.
Doug Blease
