Hi,
My 200t off switch isn't cutting out the saw.
The cables have been replaces fairly recently and have checked them again and all seem ok.
Ive also checked the connection in the handle to make sure that is touching when in the off position and all seems to be ok.
is there anything else that could be causing the issue?
Just a case of metering out the earth point, through the wires to where they connect to the coil. It is possible the spade connector to the coil has fractured but the most common area the circuit fails is the yellow and green wire from earth to the switch under the front top AV mount.
You have metered each wire haven't you?
