1 hour ago, Nick Connell said:
Control Freq do good GSM alarms that run off 12v with SIM card.
You can have 4 inputs and control 2 outputs remotely. You get a call and txt within about 4seconds of activation.
I use Takex quad beam sensors and control a siren and lighting with the out puts.
I've got a 4G router that runs a DVR cctv system with a 100gb a month data contract with 3 for about £30p/m. We have very few false alarms but quite a few actual break in attempts but with the Cctv I can look and decide how much ammo I need to take with me
Looks the job that, i will investigate
Would a inverter not drain a battery really quickly as you would have a lot of inefficacy
We used to go away with caravan and run on a 120amph leisure battery for just over 3 days, i wouldnt say we went easy on it either. My mate does these caravan rallies and can be away for a couple of weeks at a time. He bought a solar power kit that plugs in to the system and had a small storage capacitor built in to it to allow for usage whilst charging. Never went flat on him, obviously your only running a dvr unit coupled to some cameras, so not a major draw. We’d be using kettle on and off, tv, lights, shower, microwave etc.
I’m no sparky by any means and couldnt describe to you in depth or the exact science of it all, but think it would be able to run your needs. Just a thought.
