On 15/12/2018 at 00:26, tree-fancier123 said:
I've been mincing around with these Rock Exotica ones on my Dragonfly; they lock unlike a wiregate - so as long as you remember to lock them when rigging... I had to buy slightly longer machine screws for the double thickness webbing(ebay)
It does say expert use only - so you can't sue unless you can identify 75% of the arboretum
What is the thread size?  And what length you go for?  (got an eBay link?) I only just managed to get the ones supplied to bite on the Dragonfly but it bent the plate a bit as it was tightened up so feels a bit of a bodge.
m4, went for 16mm - on the Dragonfly I would say 14mm ideal as the 16mm do poke through a bit and have torn the olive padding behind - no big deal
https://www.ebay.co.uk/itm/PHILLIPS-MACHINE-SCREWS-COUNTERSUNK-FLAT-HEAD-BOLTS-M3-M4-M5-M6-M8-STAINLESS/252355920381?hash=item3ac195c1fd:m:ma-d36c5_WxqdYmyHI014dQ:rk:3:pf:1&frcectupt=true
