Hi All,
I have had a old swerber double headed mill with 2x 075's, few reliability issues maxed out in oak, but it has been an awesome start to milling.
i had the opportunity to get my hands on a few logs that are 5ft across at the bottom end with bad access for machines to move the logs as a whole.
sooo, i have decided to buy a double headed mill and a ms880 (i will run my ms650 on the other end) and the other will be sold.
I have bought a 87" bar to give a 72" cut.
MOST of the stuff i will mill with the chainsaw mill will be around 40 to 50" (though who knows whats around the corner, 2 months ago 50" cut was ample)
what are the pros and cons of cutting logs considerably smaller that the mill size.
(anything up to 35" ish i cut on a woodmizer)
has anybody ever bothered buying a smaller bar and chain for a larger mill or is it not really worth it for the 20" ish differance?
thank all
Hi Jonathan,
thanks for the reply.
how are things now you are back down south ?
the other problem with the swerber is that my ms650 would not go on it without removing the chain break handle (not enough clearance between saw and upright on the mill)
ill speak to Rob as i think some of the mills are adjustable to put a smaller bar on.
I can not really justify having 2 seprate mills and 4 saws to run them
Man do I see what you mean about bar sag, I never experienced it with my 50 inch Cannon bar.
There seemed almost 1/4 inch deflection without the power heads on and set at maximum cut.
To reduce the sag we pushed the 2 sides in 5.5" each side and it reduced it drastically.
Is there any issues with running the mill like this. Apart from if we get a bigger log we need to move the brackets back out.
Dont think that's a problem running the bar clamps set it a bit. Obvs keep an eye in the cut that the saws weight isn't bending down the way.
Also make sure yer bar is supported well when you do the bar clamps up as you can sort of force a bend onto the bar which accentuates as the change the depth gauges.
