Â
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Â
Question
aesmith
Hi,
This tree originally had three main stems, one going straight up, one to the North running near vertical with little branching until the top, and the third branch to the South where it's not shaded by anything is more spread out.  A few years ago the central stem broke off at around 30'.   Now last week the North stem failed where it branches from the main trunk. That happened during strong winds but it looks as if it was rotten internally and I'm wondering if the tree can recover. And if it can, would we be better cutting back the branch to the S to remove some of the weight on the joint?
Â
Here's the remaining tree after the severed branch was removed (visible in background) ..
Â
And close up of the damage on the main trunk. The split runs maybe 5 or 6 inches below the saw cut ...
Â
Thanks, Tony S
3 answers to this question
Register a new accountSign in
