One of the most simple ways to come back in from a limb walk (I found) is to clip your neck tether back in, and drop the tail end of your rope through a fork at the end of the limb you’ve walked out on. Then you hold onto the end of the rope through the fork, pulling your main line tight between the end of the limb and your anchor point. Then walk back in on the limb allowing the end of the rope to run through your hand whilst keeping the line tight, and your neck tether will pull your vt/rw along with you so you basically walk back in on a stationary line. Takes no time to set up and feels mega safe ?
  • Like 6
