Hi All,
Recently, I've been having some issues with the running of my 560xp. It's a 2011 model and done minimal work really. The other week, was working away brashing some softwoods and the saw cut out. Very much like I'd caught the on/off switch and the saw stopped. Checking the saw over, I seemed to have no spark. Ordered a new coil / ignition from Listers and fitted it. Since then, then saw will now run but only on full throttle. If you let off the throttle, the saw dies.
I've tried a calibration, 3 mins cutting in a log. This seemed to make no difference. Checking the (new) spark plug after it seems the saw is running lean.
I'm looking for some advice. Do I need to reset the carb some how? Am I not calibrating long enough? I read somewhere else that it could be an air intake leak, but can't see anything out of position that would cause an obvious leak.
Thanks in advance.
1 hour ago, konablaster said:
Hi All,
Thanks in advance.
Take it to your dealer . 2011 is one of the first and has one less crank case bolt than the current saw . There have been a whole host of up grades / mods to the saw since 2011  including a new carb and software . Be worth taking it in I would say .
Ok brilliant, cheers for that. I’ll drop it in soon. I don’t think it’s ever been back since the day I purchased it
