Evening,
looking into buying a cheap kubota b1400 tractor from a local bloke, and although I am confident it will run my saw bench, will it have enough power and weight to be able to lift my thor supermajic 18t pto splitter? Looking for a small tractor which would be my own, and at the same time be handy for manoeuvring chipper etc on larger work sites, and this is local and within budget.
thanks
That should give you the machine specs regarding towing and hydraulic/lift capacity’s. I’ve used the same machine at one of my customers farms for years, it’s a cracking little tractor.
