On 12/7/2017 at 16:36, buffalo606 said:
Only problem I can think of is when you then need to sharpen up in the forest with say a 7/32" file the gullet will be a bit cramped?
Not had a problem like that. Just make sure when you use the grinder you set it to go as close to the strap ties as possible then when you file it should fit in fine.
