Hi Guys,
Just a quick one,
Got a ms362 in the workshop with a ceased engine, with a scored bore and piston.
I'm going to put a new pot piston change ect.  What do you guys use, is it always Stihl parts? Or is there any pattern part suppliers you would suggest using that maybe gives you a better power out put for example.  I've heard of guys in the US using aftermarket stuff on there hot saws
Cheers
