Pete's probably still in bed....xD
Glenn , which engine do you have fitted ..?
What happens to your 'no-stress' light..?
It should flash red with the ignition turned on and the override button pressed.
It should then be a solid red/orange when the engine is running.
Finally it should turn green when the engine is running at maximum revs..
Jase..
Hi please bare with be i will come to you I no it's a lister engine on the chipper all works chips but when the engine struggles you have to ease on the bar if makes sence thanks for getting back I will see tomorrow as not really looked at the lights hadn't thought to
Do the feed rollers pull in on tick over  ?
If so then have a look under the infeed chute by the no-stress solenoid valve, there is an override tap there with a lever , the lever should be in line with the hose fittings , if it's turned 90 degrees then the rollers will infeed on tick over.....
You might find that if the lever has been turned to the incorrect position , when you put it to the correct position they won't feed in as there is a fault the previous owner was trying to cover up..
If this is the case , try the above to see what happens to the no-stress light..
If you get a green light , you should then have magnetism at the no-stress solenoid valve (under the infeed chute) , checked on the nut that holds the coil in place..
Jase..
