Ms201t muffler mod and carb adjustment
lewisyounger16
A week or so ago I put a 10mm hole in a 2013 ms201t, removed the limiter and turned the H screw counter clockwise about half a turn. I'm just concerned that's the bit I might be wrong with, I searched the Web and found that a 201t stock h screw position is 2 turns out, is that right? And a muffmod one will need to be slightly rich, so does 2 and a half turns out seem right?
Seems to sound okay at WOT with a bit of 4 stroking, I'm concerned it isn't tuned right, but it picks up from idle okay and revs well.
