Hakki pilke 37 problem
Owainlogs
Mine used to do it fairly regularly, but it hasn't for ages, I think it something to do with the length of the bolt, mine are now screwed fairly well in so it doesn't seem to klonk back and forward or it could be the spring has lost some of its resistance , you could always go for a cap head bolt 12.9
I thought about turning a kind of steel cylinder, same length as the bolt when it's at right length, so a cap head would go through it and tighten but the head would be inset so the lever wouldn't hit the bolt head just the steel sleeve,
If you know what I mean :-)
