Cone splitter pulley bore advice???
otter
Would a Pulley bore size of 24mm be right for a 20mm shaft? This would be the small (100mm) pulley to go on the drive shaft on a petrol engine to drive the belts to large pulley on the cone shaft??
Cheers
Unless Im misunderstanding , you want to put a 20mm shaft into a 24mm hole ? Its just a guess but I would say that would wobble a bit ! :biggrin: A wind up surely ?
