hi today i brought a greenmech eco 15 23.all seemed well till i thought i would check the cutting blades.they were petty dull and chipped.but there were only 2 is this right,sureley there should be 4 ?
I think the newer chippers have 2 round blades that you can turn about 3 times and you send them off to be re ground. The ones that i have used had two anyway. :001_smile:
Mmmm... think you got a couple short then!
On the 500mm flywheel there should be 4 in total(2 pairs of 2).
Have you bought it private, or can you get hold of the dealer who sold you it?
The blades sit in a pocket in the flywheel dont they, if there are no spare pockets ............
yes thats right. there no spare pockets but there is a plate welded on the other side, but not sure if thats for balance
