Hi everyone,
We've just employed a new member of staff who is shorter than 5ft and petite stature which is causing all sorts of issues with kit. Does anyone have any advice on where I can find The below-
STC boots - smaller than size 3!
Smaller size brush cutter harness. It's totally loose around her top and shoulders.
Extra extra small hi viz.
I've spent a lot of time googling this issue!
Thanks
No help sorry nick but we haven't had the same with our apprentice. Boots we found hard but gustharts found some chainsaw boots to fit eventually, I do believe Stine do some very small hi viz stuff as got 1 for my daughter which is still a little larger but she is only 9.
Strimer harness you might have to modify something yourself as I don't think you will have much joy finding anything smaller than what you have.
Might be worth a look on here
https://m.engelbert-strauss.co.uk/
As I seem to remember they did lady's work clothing.
Sent from my D5803 using Arbtalk mobile app
im only 5'6 ft in boots myself so no the struggles of being short in work wear the basic loop brush cutter harness as you just undo them and jut them down in size then for extra comfort on the souder simple bit of foam and gaffer tape into you find a small person size one but i haven't found one and that's one of the reasons i wont buy a cow horn brush cutter for as i just use them with out a harness on the r loop handles
Read more
