Has anyone had any problems with their Saw Pod? Its a great bit of kit but i've just had to do a modification to it. Basicly where the plastic feed is i've had to sew an extra seem to stop the plastic feed spinning and acting like a tornique when you pull the velcro tight! Now the feed stays in place and you get a nice wide strap to spread the pressure.
Great bit of kit!
i dont seem to have the problem of them turning. i used insulation tape on mine wrapping it around the saw sheath and the saw pod so the sheath doesnt fall out.
All I did was put the strap through the plastic buckle as if it were on your leg. Put a little tension on the strap and sew as close to the buckle as possible.:icon14:
or get some duck tape, rip a length off and cut long the middle so its half the width and stick it where you would sew.... easy:trytofly:
Duck tape looks a little bit "home made" shall we say! Doesn't create a good impression to customers if you turn up with mickey mouse gear?
mickey mouse gear? duck tape is a quick fix and if you use black you wont see it.................... i think stitching would pull out easily on the elasticated fabric...
