Canter twisted rear axle
bolla
Hi I have a Mitsubishi canter 57 plate
The original fault was very loose steering and wearing out front tyres on the inside
The garage found a bent track rod
This was replaced and the truck sent to have wheel alignment set up
I have been told that the rear axle is twisted by 5 degrees
Has any one experience of a twisted axle on a canter
Is it repairable (unbolt axle and retighten or replace parts)
what causes it to twist
Thanks
lift back end a bit, loosen appropriate nuts an bolts and put back in place..
Did it on my hilux years back, I thought it was driving funny but couldn't put my finger on it, till someone mentioned my axle was outa kilta.. I can't be sure but I think I'd backed over an oversized kerb an it threw my axle out a bit..
