Hi
I haven't much experience with a resistograph but tried today.
Having trouble understanding the results, tried different speeds/feeds. Not sure if it was to slow, seen be large area of blue not green on the graphs?
were these taken at different points on the tree?
graphs 1 & 3 are the same drill, yes?
graph 2 looks to be a completely different volume of wood.
The blue graph shows the penetration rate of the resistance of the needle through the wood & the green graph (usually shown behind the blue, though you can switch that around) shows the torgue of the needle.
Edited by David Humphries
graphs 1 & 3 are the same drill,yes?
Hi
Yes there all on the same tree, oak.
There at different locations around the tree, which does a large cavity.
I was on speed 3. Yes sorry 1 and 3 are the same, upload twice
It may just be the fact there's a lot of decay?
Edited by tree79
1 & 3 (which present as identical drills) show that there is largely intact functional wood (apart from the dip from 14 cm to 20 cm which may be a pocket of decay)
Where as the second drill shows almost no resistance (so decayed wood volume) from about 5 cm inward. A vast difference in the functional outer sapwood areas between the two/three graphs.
As long as the needle chisel is sharp, setting 3 should be OK for oak.
OK great thanks dave
