cheap post knocker
donnk
There not great to be honest, but better than a maul, they just lack the Umph to get bigger posts in.
If you get one though get the hitch mounted on the side of the breaker nearer the bottom as it gives you considerably more height on posts and is easier to work with.
I'd sooner a drop weight knocker on a digger- far more power and not unreasonably prices
I use a little breaker to knock in fence posts with my 1ton yanmar, it works fine and much easier than a maul though because you are sat back away from it you need someone with a level to watch and keep them straight.
That video with the separate bit that goes on the post first and then falls over looks like a real faff.
