If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
greengo17
Hi all,
I have an ash tree that has a wound in its trunk that stretches from the ground to about one metre in height. The wound is on the north side of the trunk. The tree is at least 30 years old and about 8m tall. I noticed for many years that there was always lichen covering the branches of the crown and also that some long branches never produced leaves but the majority of branches produce leaves every year. Only noticed about a year ago that it has this wound. I have noticed something has been boring into it. There is an ant hill not more than a meter from it. Was hoping if someone can tell me what the cause of the rot might be and if the tree can be saved? Many thanks for your help.
3 answers to this question
Register a new accountSign in
