Fransgaurd double drum winch rope.
Capstankid!
How do?
I have a 3.5 tonne double drum winch with 10mm fiber core on one side and 8mm steel on the other.
I need to replace both wires as they are just getting past there best and i am updating everything on the winch itself.
My dilemma is that I need as much length as possible for skylinning(so thin mm rope) but I sometimes double the winch up to pull trees over and am worried that if I go for the smaller rope I might just snap it.
What's everyone's opinions and would you use fiber or steel?
Sent from my SM-G930F using Arbtalk mobile app
I have had a 8mm fiber core on one side of mine, that has lasted reasonable well. Provided the wire spools onto the drum tight the crushing is kept to a minimum, not always easy.
I have possibly some first thinnings in a ridiculous steep valley coming up, and i am going to try joining the two lines with 100m of 12mm poly prop, as it is cheap and light for a simple push me pull me high lead.
I think if you go smaller than 8mm then you will have trouble with the line dropping off the pulleys or getting wrapped around the drum guard.
