Hi I have a 97 en tec 30 Dh chipper same as Timberwolf 150
would like to change the feed roller blades and also the anvil
I think I can remove the rollers easy enough to change the roller blades but not sure whats involved to change the anvil
Is it possible to see the anvil to see how worn it is
will i need to remove the hopper and flywheel to get to the anvil?
I would rather not disturb the flywheel bearings
I would like to have a go my self but if it ends up taking me more then one day I would probably be better paying some one, just a bit worried about disturbing flywheel bearings
Thanks
Hello Bolla
Both the roller blades and the anvil can be replaced without disturbing the rotor bearings.
You will have to remove the funnel and roller box in order to get to the parts.
Any of our authorised Timberwolf dealerships can undertake this work for you and details of your nearest dealer can be found on our website http://www.timberwolf-uk com
Hope this assists:thumbup1:
