Honda um616
skc101fc
I've just suffered terminal belt failure on this mower and its eaten the outer layerof the blade belt, - you know, the bit with the reference codes and numbers on it. Whats left is too heavily worn to work out accurately the size.
Do any of you landscape machinery guys here happen to know the belt size for this great machine?
I can't find anything on line so will go to the local engineers supplies once I know the size.
Thanks
Shaun
Hi Shaun your UM616 takes a special belt , it's called an SB40 , it measures 16.5mm x 9.5mm datum length 1016mm Honda part number is 22431-VD8-003
This differs from the standard 5/8" or 5L belt as these are 15.9mm across the top .
If you get stuck let me know as my supplier has stock
Sent from my iPhone using Tapatalk
