There is a 40mm tool post listed so I am guessing that, coupled with a 3mt to 2mt reducer should allow the Woodcut to fit?:confused1:
I decided to email woodcut direct and got the following by return
Our UK distributor is Axminster Tools & Machinery.
Whilst we do make a 40mm Toolpost, Axminster don’t normally stock this size but they should be able to get one in from us for you.
If you are not already aware, I need to advise you of our new Bowlsaver MAX3 that Axminster are soon to start stocking.
It has been designed for power users with large lathes like your VB36.
The MAX3 has a new 3rd extra large blade capable of a cut size up to 450mm diameter.
The small and medium blades are the same size as the small and large blades of the traditional 2 blade bowlsaver which we still make and sell.
The construction of the MAX3 is much stronger and heavier than the 2 blade Bowlsaver with most components cast.
If you are interested in a MAX3 with 40mm toolpost we can make sure there is one shipped with Axminsters first MAX3 shipment going some time in September?
So looks like it will be this one with the new bigger blade - result.
