starting to build a processor we bought a large roller table to cut square timber for our kindlet after loads of phone calls pricing processors that can only cut max 16 inches and about 15000 spending decided to do something with the table i have been cutting logs on it at 23 inches have the feed deck made 10 feet lonng 8 feet wide it takes two men at present.i am waiting for the drive motor and hyd bits and drive belt should have some bits this week when we get this bit perfected we are looking into the saw motor at present as we made a bracket to swivel the chainsaw on the end we are curently using husky 575 i will post picts at some stage would like to get it more refined me and my nephew cut two teers before noon yesterday no bother every one should take a leaf out of the americans as they pioneered the processor.
are you planning on running it from a pto eventually or sticking with a chainsaw?
im planning to build a hyd power pack by using a perkins engine either 3cyl or 4cyl i have a small power pack wich will run the infeed and log deck
For a saw, try and get an old harvester head. It has everything you need on it, and you could just cut the whole sawbox off.
Bear in mind it will need a bit of power to run it, but most will cut 24" in seconds.
