stihl fs400 problem
johnw_123
hi.
i have a fs 400 that has developed a problem.
first started to bog down after about 5mins of use,
checked for spark before starting and after and all is good.
so cleaned the carb and now it will start fine and idle as it should but on wide open throttle it bogs down unless i turn the choke lever so it is just off the full choke postion and then it will run fine (idle and full revs)...also replaced the primer bulb and lines....any ideas
thanks john.
