Anyone used these.
Ian Flatters
I personally wouldn't belt sand redwood, (I am a cabinet maker and tree surgeon) redwood is very soft and if you are trying to get a fine finish put the belt sander in the bin. Get a smothing plain to flatten the worst of the bumps then a number 7 jointing plane to flatten it then use a cabinet scrapper and you will end up with a surface that will not need sanding at all. The belt sander will leave funny fury bits. This is where the belt is joined together it takes a larger/heavier amount off. Don't get me wrong a belt sander is brilliant but only in the right application. Flattening boards is definitely not it. Invest in some elbow grease and you will be surprised.
Sent from my C6903 using Tapatalk
