Anyone know of any uses other than snooker cues for this timber, and any durability properties asssociated with it?Someone has got a huge piece they want milling.
Found this on web,
Index
Name
Ramin (Gonystylus macrophyllum)
Type
Hardwood.
Other Names
Also known as ramin telur, melawis, and lanutan-bagyo.
Sources
Grows in Sarawak, Malaysia, and south east Asia.
Appearance
Straight to mildy interlocked grain and a relatively fine,
even texture. Creamy white to pale straw colored
heartwood and sapwood - not well differentiated from
each other.
Physical Props
Moderately heavy and hard with high crushing strength,
moderately high bending strength and stiffness, low
shock resistance, and poor decay resistance. Exhibits
large movement in service. Steam-bends poorly.
Working Props
Works fairly easily with machine or hand tools but tends
to chip out on quartered surfaces and end grain. Glues
satisfactorily. Pre-drilling required for screws or nails.
Stains, paints, and generally finishes nicely although grain
filling may be necessary to achieve a smooth surface.
Uses
Used for furniture, mouldings, interior joinery, office
fixtures, toys, carving, dowels, handles, and other
turnery, flooring, paneling, plywood, corestock, and
decorative veneers.
Comments
Often used as a substitute for beech.
