  • Replies 22
Well Done guys it was the crap Chinese new ignision system that was causing it. I soldered up the old one and put it back on, fixed the problem straight away. Cheers all
Had the same with a combi cutter, mostly happens when the manufacturer changes coils and flywheels a bit. I got a refund in my case as the listing was wrong for the coil.
If backfired as yours did and is generally attributed to the flywheel going but you get cheap parts for a reason!!!
I find you've got to take a gamble with these cheap parts from time to time, I think Husky wanted something like £30 for a new coil, that would have been the end for this saw as its only worth about that!! Unfortunately for me the crap coil didn't work out on this occasion, but many parts do.
